P0447 - circuit open
Old Aug 9, 2019 | 10:05 PM
opfire's Avatar
7th Gear
Default P0447 - circuit open
Anyone know what part would need to be replaced with this code?
a new gas cap has been tried and a new DMTL pump installed
please help!!
tim
Old Aug 11, 2019 | 03:59 AM
Globetrotter448's Avatar
It is possibly the earth connection. Check on the RH front wheel arch under the liner is a connector where the "red" wire rubs through. This is the earth wire.
Old Aug 11, 2019 | 08:31 AM
DakotaTravler's Avatar
Do you by chance "top off" the fuel tank after the auto shutoff at the gas station pump?
Pull the spare and check/clean the connections to the evaporations canister otherwise the DTML pump may in fact be bad. They do fail.
Old Aug 11, 2019 | 12:01 PM
opfire's Avatar
7th Gear
I do not overfill the tank,
A new pump has recently been installed.
this red ground wire, is it pretty obvious if you remove the mud guard under the fender?
thank you!
Old Feb 22, 2021 | 02:13 PM
sndabah's Avatar
Default P0447 Range rover 2008
Did you ever figure out the P0447 code. I'm having the same issue and can't figure it out.
M3g474rd
Mar 4, 2019 10:34 PM
Geo
Sep 24, 2018 01:29 PM
Luckyjayb
Apr 2, 2017 04:37 PM
HOSER
Dec 29, 2011 12:29 PM
immortalkist
Nov 16, 2010 09:10 AM
