P2096 Lean on Bank 1
Old Nov 9, 2018 | 02:30 PM
  #21
vetalbig's Avatar
Oh man, I did replace thermostat housing too, week later code popped up! That’s interesting
Old Nov 9, 2018 | 03:47 PM
  #22
AtlantaViking's Avatar
OK, now we may be onto something! So I have it completely disassembled up to the plastic manifold. It honestly looked OK, but I may try to reassemble with some gasket maker/sealer with the existing parts and let that set up and see what happens...it has to be something in there. One thing that I've been thinking about is whether, if by any chance, the electric motor for the throttle butterfly could get out of whack. I say that because I also cleaned up the carbon around the butterfly and likely manually opened it up which caused the motor to turn. It did reset to the closed position but I still wonder about that for some reason, like maybe I screwed up the calibration of it somehow.
When I look at my freeze frame data, the absolute throttle position read 14% but the RPMs read 670. The RPMs seem like idle, but why would the throttle position be anything but 0 at idle? It may just be that I don't understand that enough obviously,
Either way - the coincidence about that whole plastic thermostat housing is waay too much. The problem has to be around there.
Old Nov 9, 2018 | 04:13 PM
  #23
vetalbig's Avatar
At some point I read a post about P2096 which stated that faulty coolant temperature sensor could be the cause. I did buy cheap thermostat housing assembly off the EBay and that included coolant temp sensor. I went ahead and ordered another sensor (aftermarket), put that one in but still getting code so I don’t think it’s that, have to look for air leaks. I have disassembled throttle body, cleaned it and carefully reassembled it back with no luck. Once again as you said has to be something somewhere in that area. Glad you mentioned it. Truck runs just fine, no flactuation at all, very steady at idle, driving it daily. I really want to get to the bottom of this. Mine is 2008 V8 with 210k miles, love the truck but very annoyed by CEL
Old Nov 12, 2018 | 09:17 AM
  #24
Update after a couple of items over the weekend:
1. I resealed the throttle body both at the plastic manifold and the sandwich'd steel gasket and took it for a run - same code. So that wasn't it
2. Next day I went ahead and replaced the MAF. The previous owner had run a KN air filter and I'm not a fan of them due to their ability to coat the MAF with oil if the filter was over-oiled. The result - no change, same code.
After each work item, it takes 2 drives to get the code to be thrown. The first to set the pending code and the second to actually set it to an active code. As soon as the truck goes into closed-loop is when it sets. So, it's consistent as hell.
Next steps: Test the EGR motor for resistance and then possibly buy new intake manifold gaskets. Even though I haven't removed the manifold, maybe during all of the jostling around removing the throttle body when replacing the thermostat housing, it got a shove. I would have thought the smoke test would have pointed the finger but the leak could be in the valley...I also may still swap the injectors from one side to the other to see if there is a weak injector in the mix..
vetalbig: If you and your buddy have the chance to swap parts, I would really be interested to see if you could swap the trottle body butterfly from his to your WITHOUT moving the butterfly at all. I still wonder about if the calibration is off. This could be a complete red-herring but that one keeps me up at night.
As usual, any thoughts are appreciated!
Old Nov 13, 2018 | 05:38 AM
  #25
vetalbig's Avatar
thanks for the info. I will get to throttle body swap the weekend of thanksgiving. There is also Land Rover dealer not far from me (I’m in Dallas Texas) I wonder how much this type of diagnostic cost, I might try that eventually when I run out of options.
Old Nov 18, 2018 | 10:47 AM
  #26
vetalbig's Avatar
Default Update
Just a little update. I’ve got injector cleaning system that I purchased a while back but never got to use it, so I tapped into fuel line directly and ran 50/50 seafoam/gasoline under 35 psi shop air pressure. What bothers me is that engine stalled on me few times while running cleaner through, the instruction video that I watched on YouTube showed LR3 being treated with identical injector cleaner and it ran smooth without stalling period so something has to be out of wack, I’m thinking something to do with air intake (possibly throttle body), i also got message low power mode while multiple stall outs. Reassembled everything, car runs fine again.
Another thing that was on my check list is purge valve, on another forum I saw a bulletin about faulty purge valve being stuck open supplying excessive air into throttle body. I unplugged purge valve from throttle body, plugged it off and drove car around. Code came back on 2 nd cycle as expected killing my hope again.
I think at this point it might be a good idea to try that throttle body swap without moving the bitterly flap.
Old Nov 18, 2018 | 03:58 PM
  #27
abran's Avatar
Normal fuel pressure is around 60psi.
I’m not surprised that the 50/50 mix did not run well.
I use BG injector cleaner at 60 psi pressure.
Vehicles run decent, but not perfect.
I can send you a can If you can’t source locally.
Old Nov 20, 2018 | 06:27 AM
  #28
Rufflyer's Avatar
Did anyone mention the PCV? It can be a source of un-metered air when it stops working correctly. I did not see it in the thread.
A smoke test could dump into the crankcase and not be noticed when looking around the intake manifold. Just a thought.
Jeff
Old Nov 20, 2018 | 08:14 AM
  #29
vetalbig's Avatar
Jeff
I did suspect pcv too, replaced with new unit but still heard a little hissing coming from it, what I did next was i took pcv out and plugged it off nicely with wine cork and ran truck for 2 min until code returned. I have icarsoft code reader ordered so I will be able to monitor fuel trims and o2 voltage closely now. Hopefully I can see something of order there that might point me to right direction
Old Nov 21, 2018 | 02:16 PM
  #30
Rufflyer's Avatar
My last hought would the cat. Before you buy one though, try a bottle of Mr. Gasket catalytic converter cleaner. It helped reduce the chance of P0420 and since 2096 has a cat component, I thought I would throw that out there and see if it sticks.
Jeff
