Parking Brake Fault, no codes showing up on blue point OB2 tool
Old Jan 16, 2020 | 08:24 AM
JOAT's Avatar
Default Parking Brake Fault, no codes showing up on blue point OB2 tool
Will this scanner work for my 2007 HSE? I've tried using it to scan for the parking brake fault im getting but nothing shows up. Scanner says no codes found.
Old Jan 16, 2020 | 02:32 PM
houm_wa's Avatar
I would recommend a legit scanner for your Rover like the IIDTool by GAP Diagnostics.
Any other indications/faults or just parking brake?
Old Jan 16, 2020 | 05:06 PM
JOAT's Avatar
I was looking at those. Which would you recommend?
Only other fault is the airbag light thats been on since I bought it. The Parking fault came on one day, went away then came back and hasn't shut off. Parking brake still seems to be working
Old Jan 16, 2020 | 06:11 PM
houm_wa's Avatar
I have the Blue Tooth version of the IIDTool and love it.
Not sure about that fault...I'd search this forum for starters. I was hoping it was in conjunction with others that would indicated something easy like the Brake Switch. Get the IIDTool, it will tell you what the issue is.
Old Jan 16, 2020 | 09:55 PM
enb54's Avatar
If you know someone nearby (you didn't post a location) who has an IIDTool you can have them read out your codes, you just can't reset the DTC errors because those devices (IIDTool) are locked to a vehicle's VIN. At least that readout might give you a bit of a hint...
Old Jan 16, 2020 | 10:33 PM
houm_wa's Avatar
Default I think you can...
...clear codes too. The VIN-specific features are the advanced ones like recalibrating and software updates and such.
Old Jan 17, 2020 | 04:21 AM
loanrangie's Avatar
I've read and cleared faults on other vehicles both D3 & D4.
abrahamd
May 7, 2023 05:32 PM
kosmo0486
Jan 11, 2018 08:05 AM
Alva312
Oct 19, 2014 10:36 AM
wassa66
Jul 4, 2012 04:14 AM
