pass side drain hose access...
Old May 17, 2016 | 06:43 PM
CATTIVA73's Avatar
Default pass side drain hose access...
Hallo,
My new to me LR3 has an ARB snorkel installed by p.o. on pass side...how can I check and possibly fix the sunroof drain hose thats soaking my carpet? ...I know that removing the side vent was one option ....any other way ?
Thanks
Old May 17, 2016 | 08:19 PM
DavC's Avatar
Originally Posted by CATTIVA73
Hallo,
Thanks
Take apart glovebox, fuse box, HVAC intake. Otherwise I have heard you can get to it by removing battery tray, fuse box in engine bay etc.
or you could just remove the snorkel, its just a few bolts/nuts. You should probably be checking the intake status anyway on a new purchase.
FYI look at windshield cowling, if its cupping up it will let water get into hvac which then drips on pass carpet. Otherwise yes it is the sunroof tube
Old May 17, 2016 | 09:31 PM
TOM R's Avatar
Water also comes in from outside the a pillars there's a bulliten , pull cowel pull a pillar covers break off top align pic seal hole, then using rtv glue around remaining holes for body clips and reattach covers
Make a deflector for water while cowel is off , do a search there's pics
Drop lower glove box pull access panel behind it and remove hvac air filters see if they are wet , if so water has been pouring in through the hvac intake
Old May 20, 2016 | 07:22 PM
CATTIVA73's Avatar
Ok I checked the cabin filter and its dry, I think it was the a/c drain hose on the side of the transmission hump...supposed to rain tomorrow so we'll see.
Thanks everybody
JustTani
Oct 9, 2014 01:42 PM
0304Disco
Oct 15, 2012 05:16 PM
deepessions
Mar 24, 2007 10:32 AM
PAXPAY
Aug 14, 2006 09:58 PM
mikemeyer0
Jan 10, 2006 01:30 AM
