PCV valve leaking
Old May 14, 2015 | 04:36 PM
unseenone's Avatar
LR003380 Courtesy bbyer
Old May 14, 2015 | 05:10 PM
cmb6s's Avatar
Sorry... that's what I get for posting from my phone and trying to keep the message short. I meant the part number for the solenoid seals (from Thorgal's post).
I actually did the PCV valve not too long ago on my car and I can say that it is perhaps the easiest PCV valve I have ever replaced. Contrast that with my '04 Range Rover which is, without a doubt, the most complicated piece of sh*t I've ever laid eyes on and took me hours if not a full day to replace the valve and associated hoses. :P
Old May 14, 2015 | 05:43 PM
unseenone's Avatar
NP
They are not sold separately via LR, the part number is Jag AJ82856 X 2 1 for each side. Be sitting down, so you can fall out of your chair.
Old May 14, 2015 | 07:34 PM
thorgal's Avatar
Yep,
Land Rover does not sell solenoid seals separately , you would have to buy entire valve cover , which comes with parameter seal and, solenoid seal , ignition coil seals and associated screws attached to it. Jaguar , on the other hand does sell it separately , but in my neck of the woods still not cheap , over 40 bucks each..
Old May 14, 2015 | 07:41 PM
unseenone's Avatar
Everyone up the chain probably made 40% on it... it probably started at 2.00 which is about what it is worth. At least you can buy it separate from Jag.
I wonder how many other parts could be crossed.. might be worth starting a project on that one.
Old May 18, 2015 | 08:33 PM
cmb6s's Avatar
Awesome. Just did the solenoid seals today. Ordered aftermarket ones from Amazon for $9/piece. There were very simple to replace indeed. I just stuck a thin, flathead screwdriver under the lip of each and gently pried up. Then I worked my way around and they came out very easily. Too early to tell whether the new ones are sealing well, but I'll keep my fingers crossed. Thanks!
04BluDisco
Jun 2, 2024 12:12 PM
Spike555
Oct 6, 2007 08:56 PM
rravenn13
Jul 19, 2007 01:33 PM
rirover
Jul 9, 2006 11:38 PM
