The perfect battery
Old Mar 8, 2018 | 12:30 PM
abran's Avatar
Default The perfect battery
I had ordered an odyssey battery from a distributor based on a recordation and although it fit the battery tray, the post was to far inward to work with the 90 degree positive cable.
So then I went with what odyssey recommends for the LR3, but was underwhelmed by the physical size, 48-720.
So after running that one for a year I called them and asked if they had any other suggestions for a battery that might take up the space, they sent the 1350. It fits!
Old Mar 8, 2018 | 12:37 PM
abran's Avatar
First one is the suggested battery,
second and is the improved choice,
third is the dual battery
Old Mar 8, 2018 | 04:00 PM
houm_wa's Avatar
Is that an AGM?
I'm running the DEKA Intimidator right now. Maybe my next one will be the Odyssey.
Old Mar 8, 2018 | 05:07 PM
abran's Avatar
AGM all the way.
over $300 though
Old Mar 9, 2018 | 01:26 PM
memphis_rover's Avatar
I thought you had to have a specific charging system for AGM? Or is this myth?
Old Mar 9, 2018 | 01:48 PM
houm_wa's Avatar
When buying a battery charger, like a trickle charger, you ought to find one that has an "AGM Mode" but as for the LR3's internal electrics, it works just fine with an AGM.
Old Mar 11, 2018 | 11:32 AM
Best4x4's Avatar
I grabbed an AGM battery at Sams Club for just under 200.00. The battery that came with my 06 LR3 was 90% of the problem when I bought my LR3 (just didn't know it right off the bat). It cranked the LR3 and tested fine, but it killed my alternator, and then caused all kinds of Can Bus faults due to low voltages. Finally took it upon myself to slap a meter on the battery. Running the LR3 was 14.5+, turn off the LR3, and the battery would quickly drop. When it got to 10.9V after just 2min being off = I quickly replaced it. Zero problems since.
It's crazy how power hungry vehicles are now. My 2014 Ram C/V is even worse than my LR3.
Old Feb 24, 2025 | 07:20 PM
RAJOD's Avatar
I go with a NAPA The Legend Professional Battery 24 Months Free Replacement BCI No. 94R 970 CA (32F) and 790 CCA (0degF)
I've had tow of them and they last around 6 years before the landrover starts to loose its electrical mind. Like not opening the rear hatch 50 percent of the time unless the engine is running.
Its strange the LR3 can start just fine and the batter will even pass testing as good but it will be off just enough to start messing with the electronics due to low voltage. If I run the heated seats for long can be an issue until I get a new battery.
6 years is good enough for me with our cold winters. Someone mentioned Lithiums anyone try one? They are $750.00 no idea if they are any better only lighter and cost more. They rufuse to test or list CCA which is telling.
LR3 Car Battery BCI Group 49 / H8 Replacement Lithium LiFePO4 Automotive Battery
Regular price $999.99 Sale price $749.99
30
People are viewing this right now
  • Group Size - 49 / H8
  • Voltage - 12.8 V
  • Weight - 19.8 lb.
  • Capacity - 60 Ah
  • Cranking Amps - 1500 CA
  • Dimensions - 14.0 in x 6.9 in x 7.4 in
  • Built-in jump starting capability.
  • Fully integrated battery management system (BMS).
  • Immediately shed over 30 pounds from traditional batteries.
Old Feb 28, 2025 | 12:02 AM
DakotaTravler's Avatar
Lithium are not starting batteries.
snowdude
Apr 23, 2009 10:07 PM
RichardBlank
Dec 23, 2008 05:44 PM
DriveAwayDreams
May 21, 2008 07:43 AM
das
Mar 25, 2008 09:10 PM
iJeremy
Oct 12, 2006 03:21 PM
