A Pillar panel noise
Old Sep 4, 2023 | 02:49 PM
lenzda's Avatar
Default A Pillar panel noise
I replaced the clips of my A Pillar cover with the clips from Atlantic British and now I have a terrible wind noise when driving on the highway. Anyone else have this issue?
seems like the top of the cover isn’t secured tight enough and is letting wind get behind it. I can hear a whistling from the inside of the A Pillar when it’s “quieter” and not make the loud fluttering noise.
FYI I replaced the clips while chasing down a water ingress issue.
Old Sep 4, 2023 | 02:57 PM
SeattleDriver's Avatar
That’s a common issue. Make sure you’ve fully seated the clips, a firm whack with the palm of your hand may be required.
Old Sep 5, 2023 | 06:04 AM
lenzda's Avatar
Thats what I assumed too...gave them a couple good firm whacks. I may take them off and try a different set of clips.
The Atlantic British set came with 2 clips that were different - does it matter which holes these clips are associated with?
Old Sep 5, 2023 | 09:12 AM
I believe the oddball clip goes near the top, but the kit comes with instructions and specifies.
Old Sep 5, 2023 | 01:39 PM
lenzda's Avatar
I put the oddball clip at the bottom. Unfortunately my package didn’t come with any instructions. Couldn’t find any information online either in regards to clip placement.
sounds like this might be a user error.
Old Sep 5, 2023 | 02:28 PM
I was wrong, it is the bottom clip which is unique per the LR installation instructions, I confirmed with my manual. My best guess is the clips are not fully seated or your trim has warped slightly (it happens).
Old Sep 5, 2023 | 08:43 PM
lenzda's Avatar
It’s got to be warped trim. I’ve hit the pillars pretty hard repeatedly.
Old Sep 5, 2023 | 09:10 PM
DakotaTravler's Avatar
Just pull on the trim, if it comes up then it is not seated. They are difficult to fully seat, especially along the bottom half. I have sets of new trim that came with my windshields and really had to whack em - to the point of worrying about breaking my new windshield.
Old Sep 8, 2023 | 01:56 PM
kajtzu's Avatar
Please refer to this TSB for positioning of clips (and their part numbers) https://disco3.co.uk/gallery/albums/...water_leak.pdf
Old Sep 9, 2023 | 10:40 AM
lenzda's Avatar
Thanks for the TSB link. Looks like I’ve got the orientation right. Just need to keep pounding on the trim.
Ratledge
May 10, 2024 12:45 PM
Godspeed ZRZ
Aug 22, 2023 08:44 AM
neumaiek
Range Rover L322 (3rd Gen)
May 27, 2019 10:20 AM
KernowDiscovery
May 30, 2014 10:44 PM
wholder
Feb 10, 2010 03:29 AM
