Please don’t hate on me… air ride advice.
Old Jan 1, 2023 | 08:21 PM
houm_wa's Avatar
I don't know what you mean by saying they are all in England. We may be talking past each other. The IIDTool is made by GAP Diagnostics and is made for a specific model. It's certainly not cheap, but it's worth it.
https://www.ebay.com/itm/11424604264...hoCLogQAvD_BwE
Old Jan 1, 2023 | 08:51 PM
Koolminx's Avatar
I don’t know why my phone started inserting those weird signals but I looked up the LLD scanner and it showed a bunch of them for sale over in England. But I didn’t do a eBay surgery anything this one is 525 bucks I’m pretty certain he’s going to not buy it lol but I’m going to send him the link. The ones I saw in England were 250 pounds which is around 380 to 400 bucks depending on exchange rate I guess.
Knowing him, he will search for a cheaper one somewhere
Old Jan 2, 2023 | 03:01 PM
Koolminx's Avatar
What do you guys think about this scan tool? Will it perform the same job as that $500 one that you sent the link to?
https://a.co/d/irlxV2W
Old Jan 2, 2023 | 05:12 PM
SeattleDriver's Avatar
The Autel AP200 is supposed to be a good option per the Disco3.co.uk forums. I’ve not used it and the GAP IID is the most popular here. If buying the Gap used budget $50 to transfer the license to your vehicle.
Old Jan 2, 2023 | 05:43 PM
Koolminx's Avatar
I’ll send that info to my buddy! Thank you guys, this saves me a ton of time I’ll never get paid for cause my buddy is broke like me. 🤣🤣
when he gets the codes I’ll post them here if the cure isn’t immediately a stand out issue.
if it is I’ll post the solution 😎😎
Old Jan 2, 2023 | 06:55 PM
DakotaTravler's Avatar
Originally Posted by SeattleDriver
If the rear isn’t raising, there is probably a leak in the reservoir or an issue with the rear valve block. The springs should raise off of reservoir pressure, and the rear raises first.
Not really. The system will use stored reservoir pressure, initially, but gallery pressure is monitored and as soon as it drops below a threshold (I think 150psi?) the system closes the reservoir valve because it is inferring that it is empty. And this is why one the truck is at height the compressor will run for a while - to refill just the reservoir to 250psi.
Old Jan 2, 2023 | 06:59 PM
Originally Posted by Koolminx
Number 5 and number 3 in this schematic have been replaced.
the front block just under year ago, the suspension began working normal after that. Then just recently it stopped again.
teying to get a good timeline of everything he did in a row is difficult.
today part 3 was replaced.
no change in pump reaction.
not replaced is #5 and it’s specific location is unknown by me. That’s the only part listed with a pressure sensor. Perhaps it trips because it’s bad and shuts off pump before the pressure is enough to lift the rear.
the reservoir does not leak. I also could not find any compromised o rings or seals.
repeated shutting off and starting to get a total of a few minutes of pump run time does nothing.
this schematic does not list the part bolted dead center over third member, so I cannot research it’s purpose.
I’ve used search function here and on goodie to poor results.
the codes present as of now are listed above in the picture I. My earlier post.
5 and 3 replaced. But 5 was not replaced? Confused
Also, just to be sure. The front and rear valve blocks, 3 is front and 5 is rear, may look alike but are not interchangeable. Number 4 is the center valve block and ONLY monitors pressure of the gallery and regulates reservoir pressure. It does not control any air from front to rear, etc.
Old Jan 2, 2023 | 07:02 PM
If you have a shop compressor, you can get some push connects (6mm) with a schrader valve and manually try to inflate the rear and see what happens. 1/4" can work too but its not the same as 6mm... To do so you would want to locate the rear feeder line from the center valve block. Center valve block is within the plastic housing of the compressor, just forward of it. Two lines head back from it to the rear, one goes to the compressor so not that one.
Old Jan 2, 2023 | 08:19 PM
Koolminx's Avatar
Yes fat thumbs 4 was not replaced my bad.
Old Jan 2, 2023 | 08:20 PM
Koolminx's Avatar
I thought about manually doing it. But left it up to my buddy to do on his own.
