Poly Bush for LR3
Old Jan 10, 2017 | 06:17 PM
clarkritchie's Avatar
My shop quoted me at 8.4 hours of labor, and is why I linked to my other thread...
Old Jan 11, 2017 | 12:38 PM
houm_wa's Avatar
Just sounds crazy...
Old Jan 11, 2017 | 12:39 PM
houm_wa's Avatar
I suppose the thing to do, if I were doing it....would be to wait until I was R&R'ing the lower control arms anyway, then have them press the new polybush into it...and I could save the old one for a spare. That way the delta-labor would be minimal and the price not crazy.
Old Jan 11, 2017 | 01:02 PM
BritishautoworksSD's Avatar
Sounds like there's a market for used arms with new bolt joints and poly bushings pressed in.
Old Jan 11, 2017 | 04:02 PM
KMET's Avatar
Some lubricant and rubber mallet are all you need for pressing poly into arm. That's actually the easiest step... next to lower ball joints and pushing axle back.
Removing stock bushing from arm (torch, air chisel, vice) I'd say number 2...
I also needed to file down some burs inside after removing bushings.
Most time consuming part for me was reattaching arm (Axle kept sliding back in than pulling CV as id finagle arm back into place)
Old Jul 18, 2018 | 05:13 PM
Has anyone done every bushings for the suspension in poly? Atlantic British sells a complete kit for around $500
Old Jul 19, 2018 | 04:55 PM
I've only done the front lowers and the install was no different than the standard bushes.
I think the durability of the poly bushes will be great but I don't know if I would appreciate the firmed up ride if you did the whole truck.
Old Dec 19, 2018 | 03:53 PM
metallicpea's Avatar
I'm just wrapping up the install of complete rear bushings on mine. I went with the Orange Polybush complete set. Ended up with Land Rover lower outer knuckle bushings and Lemforder upper knuckle bushings.
I can let you know how the ride is after I finish, have it aligned and break them in.
In hind sight, I think I would have gone with the AB arm kit with green poly bush complete arms with hardware. Salvaging the original arms was not at all worth the savings and mine are fairly rusty. Also, would go with Lemforder knuckle bushings upper and lower for cost reasons, as far as I can tell, Lemforder makes them for Rover.
I only had to cut two bolts. The rear bolt on the upper arm on both sides. Those bushings were really jacked too - probably most of my tire wear issues.
I replaced all the hardware with a mix of the AB kits and used Land Rover parts for the three captured nuts and the upper rear bolts. I reused the original monster lower shock mount bolts as they were super clean still - just replaced the nut.
I used a 27 piece press and pull sleeve kit for the knuckle bushings. It was under $100 on ebay and worked well enough. Don't overlook the lock ring on the lowers. I did not use it for the control arm bushings, as they were rusted and too stubborn, but I used the one piece from the kit to snap the upper rear tapered sleeve out of the control arm and a hydraulic press I have access to - I cut them in two places first. On the rest of the control arm bushings I used a sawzall or hack saw to cut the sleeve then mangled it out with a chisel and hammer. Only the lower rear bushings needed to have the rubber drilled out before I could access the metal sleeve.
Not a fun job, but would have been faster, less frustrating and turned out better if I had spent about $300 more on the complete arms.
Wish me luck on the last of it. Hoping to be ready for an alignment by the end of this weekend. Only need to remove the last arm, sandblast and repaint it before wrapping this up.
Old Dec 19, 2018 | 04:15 PM
my upper arms I think for the pair new arms, bolts and outer bushings was only $320 ish
Way easier to just chop out replace it all and move on
Old Dec 19, 2018 | 04:24 PM
Yeah, after all of this, I agree with you.
I was attracted to the long term durability of the polybush set as well as it's relatively low cost, but after having to buy the hardware separate, it's not that much cheaper. Certainly not enough to cover the time and hassle. I guess I didn't know how long the non polybushes would last. On a previous car not LR) I had the same set of bushings go out every 25k or so. On a vehicle this heavy I could see the bushings taking quite a beating, but after getting into it, most weren't that bad and I think they were probably all original.
Plus the old bushings put up a pretty good fight coming out of the arms.
