"POP" when flexing
Old Apr 30, 2020 | 03:46 PM
houm_wa's Avatar
Default "POP" when flexing
Hi all,
My '06 is exhibiting a loud "POP" when the suspension flexes. It sounds like it's coming from where the control arms are. Ball Joint(s) maybe? Any way to check for wear so that I can identify which one? Could it be something else? I'd say maybe the axle but it's specifically with suspension flex (only).
Thoughts?
Thanks
Houm
Old Apr 30, 2020 | 06:51 PM
DakotaTravler's Avatar
Could be the ball joints, but the sway bar links a weak point prone to failure. Same with the tie-rods. If you think its the ball joints, jack the entire front end up, secure the vehicle well then deflate the bags. Lets you move stuff around a lot easier.
Old Apr 30, 2020 | 07:32 PM
houm_wa's Avatar
Thanks. I've had tie-rods wear out, but never this sound with them.
Old Apr 30, 2020 | 08:10 PM
houm_wa's Avatar
Default Sway bar
End links...I've had these fail before too. This sound is just a little different. I'll have it looked at, though, before I throw parts at it. Thank you!!
Old Apr 30, 2020 | 08:14 PM
my pop was the sway bar link
Old Apr 30, 2020 | 08:17 PM
houm_wa's Avatar
Default I totally know that pop though...
...and don't think this is it.
Old May 19, 2020 | 04:53 PM
houm_wa's Avatar
...looks like it was indeed sway-bar related. I had the bushings and both end links changed out and it's right as rain.
Old May 19, 2020 | 07:40 PM
Glad its sorted
chrisc2683
Mar 15, 2020 07:03 AM
zuke
Dec 20, 2018 12:34 PM
Dtrain36
Mar 5, 2015 07:43 AM
wheelgarage
Oct 21, 2012 12:37 AM
azaky
Oct 18, 2010 07:04 AM
