Suspension Fault and Knocking
Old Mar 4, 2015 | 11:38 AM
Dtrain36's Avatar
7th Gear
Default Suspension Fault and Knocking
Hello,
My 2006 LR3 (70K miles) is currently in storage in San Francisco. I am coming back to the states in a couple of weeks and need to get my LR3 fixed for when we return. A couple days before I left, I noticed a knocking whenever I went over the slightest bump. Specifically, whenever I turn to the right and go over a curb, there is a loud knock coming from the front right tire. Also, I started getting suspension faults, not allowing me to change suspension heights.
I do not have an extended warranty, so I will be out of pocket for all the expenses. Should I find an independant garage in the bay area, or go to a dealer to get these problems looked at? My wife will be taking the car in, so I wanted to give her the most information I could.
Thanks a lot!
Old Mar 4, 2015 | 06:10 PM
TOM R's Avatar
Sounds like you need an Indy shop, maybe suspension bushings? Wheel bearing, cv axle?
Old Mar 4, 2015 | 07:12 PM
houm_wa's Avatar
Very probably that it's the lower control arm bushings. Could also be the swaybar bushing but if the knock is really that loud it's almost a cinch to be the LCA bush.
I think the suspension fault is unrelated. Start with the usual suspects: check battery, rear brake lights (all lights back there for that matter) and the brake switch.
Old Mar 5, 2015 | 07:43 AM
Dtrain36's Avatar
7th Gear
Thanks a lot guys! I'll be looking for an indy shop near my house.
06Range
May 8, 2013 09:01 PM
LR03NJ
Mar 5, 2010 07:37 AM
anhernandez
Aug 18, 2009 12:47 AM
