Problem voltage BUS can system
Old Dec 3, 2014 | 09:18 AM
anasko87's Avatar
Hello to all
I have Range Rover sport 2006
I have this fault at ABS module: C1A00-88"Control module {bus is off } "
this fault always appears while driving the car
I checked the can bus wires ,all is okay.
also this fault not appears while the car at it's place.
I changed the ABS module and the brake switch ,no change .
Is someone face like this problem?? .
Regards
Anas
Old May 24, 2017 | 07:19 PM
discovery254's Avatar
3rd Gear
Exclamation Transmission fault code
Hi there,
Perhaps someone can help with my situation. Recently my 06 LR3 gave me a "Transmission Fault, Limited gears available".
Shortly after, my stereo went off and the nav screen started flickering on and off. After looking around in the forums, I checked the Integrated Transfer Case module and everything checked out. So did both fuse boxes (the one under the lower glove box was so much fun to put back in).
I saw no sign of corrosion anywhere and I still have the fault code popping up. What strange is that the gauge cluster dies if I rev the engine and comes back on when it's idling.
Would anyone have had a similar experience? what was the solution?
Thanks
John
Old May 24, 2017 | 08:34 PM
EastCoast's Avatar
With so many random faults, I would check your battery and/or alternator for proper voltage. The brake switch can also create strange random faults and is both inexpensive and easy to replace.
Old May 25, 2017 | 05:20 AM
Phifross's Avatar
Dear Discovery 254,
I would also check first the battery and if it's a new one, the battery voltage, they are very sensitive about the voltage. The brake switch is easy to change and cheap, why not...
After that, for me it was the instrument cluster, the plug behind it.
As for me it would the third thing I would check. Mine was a little loose and when you move it you will have the fault coming and disappearing.
If suddenly you are interested I have also the Blackbox falutmate to sell.
It can really help too. Let me know.
Me I have sold my Land Rover, too many problem with it, I think I had a really wrong one... I hope it is not the case for you.
I hope this can help you.
Have a nice day !!!
Philippe
Old May 25, 2017 | 03:03 PM
3rd Gear
Thanks for the response guys.
I have replaced the brake switch withing the last 4 months and the alternator in the last 3 months. I'm getting about 13.5 v when the engine is running with electrical accessories on. How can I test the brake switch to see if it's the one causing all the problems?
Old May 26, 2017 | 06:03 AM
Phifross's Avatar
Dear Discovery 254,
The brake switch takes a long time before to spoil, not four month...
If I was you I would go behind my instrument cluster and check the plug....
It is not too hard, more or less 30minutes maximum.
Please let us know... I'm curious about it.
In fact the instrument cluster plug is a well known problem on the Land Rover, Range Rover....
Sorry again but cheer up !!!
Old Jun 7, 2017 | 07:58 PM
3rd Gear
I have not had a chance to work on the LR3 for a while.
I tried cranking it today and it was a bit sluggish. Checked the battery voltage and found it to be 11.5 volts. What I found rather interesting was the output with the engine running was a whopping 18 volts. I curious to know if this is because of the low battery voltage. Either way, I'm charging the battery up again( it's been checked and found to be in good health) and seeing if I'll get the same output with the engine running. A new alternator is in the works as well since the one I have is still under warranty.
I'll keep you posted.
PS. I checked the instrument cluster connection and no changes were observed.
Disco2 MTL
Dec 15, 2014 01:18 PM
Landyman37
Nov 18, 2012 11:40 AM
Dave Plummer
17
Jun 17, 2012 08:18 PM
Darover
Oct 28, 2009 08:19 PM
jmerrill
Mar 5, 2006 01:38 PM
