PSA: Brake Rotors can crack w/ stuck EPB (parking brake)
Old Aug 30, 2021 | 10:04 AM
The_OGCJR's Avatar
Default PSA: Brake Rotors can crack w/ stuck EPB (parking brake)
Making this thread so others can find it during a search and see that they need to check their rotors asap.
So it is common knowledge that the EPB (electronic parking brake) can seize on our Lr3's.
When this happens we all know it can create a-lot of heat and destroy wheel bearings, brakes, etc.
AND it can crack your rear brake rotors.
See pics.
This is the driver side rear Powerstop z36 rotor with less than 1000 miles.
For clarification; I drove 55mph for approx 2 miles when the wobble started. I should've pulled over sooner.
The cracks on these rotors go all the way through the rotor hat and that is too big to leave on the vehicle.
These cracks are called "heat checking" if you want to google that. And it is o.k. IF you have small ones that your fingernail can't catch when you scratch your nail over it.
Attached Thumbnails PSA: Brake Rotors can crack w/ stuck EPB (parking brake)-cracked-powerstop-1.jpg   PSA: Brake Rotors can crack w/ stuck EPB (parking brake)-cracked-powerstop-2.jpg
Old Aug 31, 2021 | 07:04 PM
COSPILOT's Avatar
See pics.
I’m concerned enough that during this last brake job I fully backed off the shoes and refuse to engage the EPB. I only park on level ground so it’s sort of a non issue, but I’m done dealing with this random issue.
Discorama
May 19, 2021 03:56 PM
COSPILOT
Dec 19, 2020 12:06 AM
mirepoixmatt
Oct 9, 2014 07:34 PM
NJHokie
Mar 14, 2013 09:41 AM
