PSA on changing your PCV
Next time you are doing some basic maintence, just throw one in. By service records, mine was changed around 60k and 5 years ago. It went bad this weekend, and really made things tough. Low power, misfires and a huge smoke screen above 2000RPM or under load. Asked the question here without any real assistance, so for those searching later hopefully this will help. If you all of a sudden have smoke, reduced power and misfire codes (mine were 2,4,6,8 cylinders) first place to look is the PCV. I fully recommend just changing it out ahead of time.
Correct for the V8 engine. I believe it's part of the MAP sensor for the V6 and looks completely different. Regardless, it's never something that's part of any maintenance schedule, but always a good idea to do on every make/model of car. I typically try to replace mine at least every 75,000 miles... more often if they are particularly prone to failure or cause huge problems in the event of failure (e.g. with the 2003-2005 Range Rover).
Also, as a note, my MPG has improved as well after changing. I would assume if yours is still functioning normally it might not. Now when the valve goes bad, you will burn more oil than fuel, but I assume there was some type of decline of the valve. A trip from NJ to VT and back a few weeks prior yielded 16.5 MPG. My same trip after the new valve this past weekend was 18.2. 400 miles on the tank. I also ran a can of seafoam through the tank to help try and clean out some of what burning oil gunked up, but still, fairly good gains. I was getting those MPG's last year, and recently saw the dip.
