PVC Noises
I'm a little paranoid about the PCV system now (see https://landroverforums.com/forum/lr...morning-79655/) and I noticed on the new engine, there's a pronounced hiss or suction noise that comes from the PCV valve on top of the engine at idle. It is especially noticeable when I remove the dipstick while the engine is running.
Is this normal?
Is this normal?
The crank gases recirculate back behind the TB and I hear similar when under my hood. As long as the fuel trims look good I wouldn't worry about it.
In my experience the software on these bad boys is pretty sensitive in terms of what it sees as out of limit resulting in a check engine light.
I have the exact same thing. However driveability is same. I tried replacing PCV with no luck, so I have two good PCV's, and I have the hard pipe that goes from the PCV back to the engine, will see if that changes anything. I think the hiss comes from one of the fittings on the PCV or the pipe fitting.
I still drive it with the hiss...
bosshogt
07-23-2011 10:01 AM
