Question about water pump replacement
Old Feb 9, 2014 | 09:49 AM
mirepoixmatt's Avatar
Default Question about water pump replacement
Gents: 137k on the rover and going to have my Indy do my belts. Researching that, I have questions.
Plan is : to replace both belts. Not just the one. The. I read some pulley should replaced if you're doing belts. Ok. I'll do that too. Why not. But what about water pump on this thing? When do these things tend to crap the bed and if this was your truck at 137 with the original pump, would you? What else?
I looked at cubby to see if I could find the water pump question in the Maintenance schedules. Couldn't locate. Thanks for help guys.
Old Feb 9, 2014 | 11:40 AM
willrok13's Avatar
Opinions may vary, but the odds if it failing are starting to turn less in favor of it hanging in there. And when it goes, you're stuck. But, if you decide to stick it out, at least do the tstat if you have not. That is more likely to go sooner rather than later, and at least the pump may give you a growl or weep slightly before checking out. The tstat will be much more spontaneous and run a greater chance of cooking your motor. Just my .02.
That info probably will not be in cubby. There's no real interval for a pump like that.
Old Feb 10, 2014 | 03:52 PM
unseenone's Avatar
Here are the components I replaced all as a set. I did not do the water pump, but I now have plans to, pictures would be nice if you do it yourself.
PQR500330 Serpentine belt, primary belt, lr3, 4.4l
PQS500221 Ac belt, range rover sport, 4.4l 2006 - 2009
PQG500030 Belt tensioner, serpentine belt, range rover 2006 - 2009
PQG500220 Belt tensioner, ac belt, range rover sport, from 7a113766 2007 - 2009\
PQR500350 Idler pulley, lr3, 4.4l 2006 - 2009
West Slope Rover
Aug 20, 2010 07:19 AM
West Slope Rover
Aug 14, 2010 08:07 AM
lipadj46
Jul 8, 2009 03:58 PM
Jawbox
Mar 10, 2009 07:29 PM
bigugly82
Mar 27, 2008 04:12 PM
