Radiator sealant
Old Feb 5, 2022 | 04:38 AM
Altitudes's Avatar
Default Radiator sealant
Hello,
Does sealant still work as it should if you pour in the reservoir but take like 2 days before starting the engine?
Old Feb 5, 2022 | 07:48 AM
kajtzu's Avatar
I’m sure you’re aware of it but that isn’t the most optimal way to fix a leak…
Old Feb 5, 2022 | 10:19 AM
DakotaTravler's Avatar
Replace. The radiators are not expensive. Sealant is a temporary fix, if it works at all. You can open up the upper radiator hose and add it that way. The expansion tank is not really a reservoir.
Old Feb 5, 2022 | 10:33 AM
keninnc's Avatar
Replace....if anything starts going wrong with the engine you will start second guessing yourself from using the sealant. Same goes with head gasket sealant.
Old Feb 8, 2022 | 12:02 AM
Altitudes's Avatar
Thanks for the guidance. I tasked the mechanic to take time and find the leakage. It was as some socket.
Thanks
flybd5
LR2
Nov 12, 2021 07:10 PM
dougn
Oct 15, 2019 08:12 PM
malibutj
Dec 13, 2010 01:24 PM
carlos84
Sep 12, 2010 01:41 PM
chrisusvi
Apr 27, 2007 09:48 PM
