rear drive shaft
Old Aug 6, 2015 | 08:02 PM
schwaggy's Avatar
Hardy Spicer or simply Spicer, aka GKN I think - you got a quality part coming.
I'm still confused as to why LR didn't put a zerk on the U joint in the shaft as stock.
Old Aug 6, 2015 | 08:21 PM
unseenone's Avatar
Why do that when they can sell a drive shaft!!
I suspect it's as much age as miles with the rubber stuff...
Old Aug 6, 2015 | 08:24 PM
TOM R's Avatar
Rear joint is fine front one is slinging grease and bearing bad so do not want to f up the replacement diff
Old Aug 13, 2015 | 04:36 PM
TOM R's Avatar
New ds came from lucky 8 today, bout 30 minutes for install looks nice, new one looks rebuildable , factory on has rear u joint staked in, never seen that before guess its cheaper than clips
Old Nov 22, 2015 | 06:04 PM
Crosbo's Avatar
Does anyone remember specifically which tools it takes to R&R the rear drive shaft on the LR3? I'm about 1,600 miles away from home with a very limited set of tools. I want to make sure I have all the tools I need, before the replacement arrives later this week.
Thanx in advance for your assistance.
Old Nov 22, 2015 | 06:53 PM
TOM R's Avatar
You need a set of inverted torx sockets, harbor freight sells em , ratchet , metric socket for carrier bearing and a second set of hands
You can probly do it in off road mode but I suggest off road mode and back up onto ramps
Old Nov 22, 2015 | 10:31 PM
Crosbo's Avatar
Thanx for the info Tom. I won't have a 2nd set of hands, so will have to figure out how to improvise.
thanx
Old Nov 22, 2015 | 10:42 PM
TOM R's Avatar
Just dont drop it on your head , long *** shaft
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
khuds308
May 12, 2008 09:38 PM
discotx
Dec 15, 2007 03:30 PM
