Rear fog light dash light flashing
Old Jan 9, 2020 | 09:55 AM
Cziggy's Avatar
Angry Rear fog light dash light flashing
So this has to be hands down the weirdest issue Ive had to date yet. The preface the issue, I replaced the thermostat with the housing and this issue occurred. When I use my left turn signal the rear fog light indicator light on the dashing with flash in unison with the turn indicator. I don't have a rear fog light installed and this is just an annoyance but Im ready to just pull the fuse for the rear fog lights. Does anyone have any remote idea when I can do to troubleshoot this?
When I replaced the coolant thermostat with housing there was some coolant that leaked out and only a small amount. But it only went in the front area in front of the engine which easily would get wet in water and I have never had this issue. Does anyone have anything I can grasp at to check? thank you.
Old Jan 9, 2020 | 11:59 AM
houm_wa's Avatar
What do you mean when you say you do not have a rear foglight installed? Do you mean there is no bulb in the assembly for the rear foglight? I believe the rear foglight function is standard on all LR3s.
Old Jan 9, 2020 | 12:06 PM
Cziggy's Avatar
I honestly didnt think I had them since they were obvious. I just assumed as it is possible. That bit can probably be ignored about the issue
Old Jan 9, 2020 | 12:33 PM
houm_wa's Avatar
I would turn on your rear foglights and go outside and check to see if the bulbs are burnt out or even installed. Maybe start there and move on to fuses and relays.
Old Jan 9, 2020 | 01:00 PM
DakotaTravler's Avatar
Odd.... trailer harness? Not that the trailer harness should connect to the rear fog lights. Or so I would assume.
Rufflyer
Oct 10, 2019 06:32 PM
AZRover
Feb 19, 2014 02:08 PM
mtrdrms
Feb 20, 2013 06:24 AM
bikeG976
Nov 26, 2010 04:34 PM
nyyrus
Nov 14, 2010 04:41 PM
