rear hatch removal
Old Oct 8, 2014 | 11:12 AM
TOM R's Avatar
Default rear hatch removal
I want to swap out the upper rear hatch, there are 2 boots where wiring goes into it, drivers side is 2 big plugs so that's easy,
passenger side has the washer hose 1 wire and 2 coax cables
I can unhook everything but 1 coax, it runs up to the brake lite area and we can't figure out how to get to it or unhook it, I followed it in the cab but it does not unplug anywhere in the harness.
the rover tech can't figure it either , they seem to be some type of antennae signal boosters
looks like it goes to a block directly under the brake lite but I cannot even push the block out because I cannot access it enough to get to one of the tabs
the brake lite is permanent glued in
ideas??
Old Oct 8, 2014 | 07:15 PM
Rufflyer's Avatar
Default GPS antenna?
When I was doing some research for adding a cell phone booster I looked at the antenna diagram in the manual. As I recall the wart on the roof has the cell phone and satellite receiver antenna and the GPS is in the bulge with the upper brake light. That part, I believe is glued in place and is hard to remove.
Old Oct 8, 2014 | 09:14 PM
TOM R's Avatar
Probly it , rover tech just know some type of antenna or booster but not how to access it since the brakelites glued on
Old Jan 5, 2015 | 02:22 PM
TOM R's Avatar
followup, apparently further research has led me to the fact that you cannot unplug that cable without breaking the 3rd brake lite for access and installing a new lens
we did attempt cutting the lens out but the body gap around the lens will not accomidate any windshield tool we have
wish I knew what it was I would just cut the dam thing off
cutting it is an option if someone knows there I can get a real small coax splice, similar to real skinny cb coax
worst part about it is the factory service manual is wrong it shows the second coax going to a surface mounted module on the hatch just like the first coax that you can just unplug, both the 05 and 06 I have are the same though with it running up under the Brake lite
Old Feb 8, 2015 | 07:27 PM
TOM R's Avatar
Gonna do this swap, but now I can't get the donor open, guess the battery is to dead, is there a bypass to unlatch the hatch
Old Feb 9, 2015 | 05:06 PM
spiderman's Avatar
Default how to open hatch with no power
here ya go,
But I would just charge up some batteries and save all the labour.
Last edited by spiderman; Feb 9, 2015 at 05:07 PM. Reason: link was posted twice, removed one
Old Dec 18, 2022 | 04:49 PM
crayfish's Avatar
Default Replacing LR3 upper liftgate
how did the replacement of the upper lift gate go? I’m looking at doing the same thing … any recommendations regarding the coax cable and the spray hose …
thanks
drzjoint
Sep 6, 2008 09:39 PM
rookie
May 10, 2008 03:07 PM
Roveroh
Mar 16, 2008 09:13 PM
pilsner
Jan 13, 2008 04:00 PM
tsuami1
Nov 12, 2007 12:14 PM
