Rear is sagging - Suspension Inactive, HDC Inactive
Old May 7, 2018 | 03:37 AM
ezambia's Avatar
Default Rear is sagging - Suspension Inactive, HDC Inactive
Goodmorning,
I have run my LR3 for over 6 years without major issues until I had a fuel pump and rear height sensor problem which I replaced.
1. Replacement the entire unity together with the sender unit and now my fuel gauge is not reading at all.
2. Replaced both Rear Height Sensors with brand new ones Part Number RQH100030 which I presume works on both Right and Left.
PROBLEMS
1. The gauge shows no fuel despite filling it with 40litres of diesel.
2. The front of the vehicle has lifted up and readings are also confusing
Front Right Reads as follows:- Voltage 2.49V, Height = -76.3mm (Negative)
Front Left Reads as follows:- Voltage 2.47V, Height = -34.2mm (Negative)
Rear Right Reads as follows:- Voltage 1.28V, Height = >>> (No Reading)
Rear Left Reads as follows:- Voltage 1.34V, Height = >>> (No Reading)
What should be the correct Voltage as I have read that the height must be Front = 49.2mm +- 2mm and Rear must be 48.3mm +-2mm.
How do I switch off the Suspension and HDC inactive. Please NOTE that I bought a brand new battery and voltage is ranging from 13V (Off) to 14.2V (Engine Running)
Emmanuel
Old May 7, 2018 | 03:24 PM
houm_wa's Avatar
Do you have an IIDTOOL? If not, get one, and re-calibrate the EAS.
Old May 8, 2018 | 06:28 AM
ezambia's Avatar
Hi,
I am using the Foxwell OBDT2 device and I selected reset and that height is still the same.
Emmanuel
Old May 8, 2018 | 10:14 AM
abran's Avatar
Get an IID tool, anything besides Autologic or factory SDD is pointless.
Ada2016
Build Threads
Jan 31, 2018 01:53 AM
Ada2016
Jun 23, 2016 05:23 PM
mrbowenz
May 18, 2010 05:12 AM
Nato
Jan 19, 2010 12:40 AM
devildog
Dec 24, 2008 06:02 AM
