Rear seated heat light go on then off
Hi all,
This thread is all about the rear seated heats. The left one behind the driver works. The one behind the passenger is the one I have the issue with. If you push the button in the centre console, two orange lights come on for 1 second and then turn off. If you press it again nothing happens.
1) I checked the wiring under the seat and they appear to be no lose connections
2) I haven't checked the fuses because I think there is only for the rear and the left one works so it cannot be this.
So could it be
1) the actual switch or
2) Heated Seat Module 6MXN815A02
One idea I have was to use swap the Heated Seat Module from the driver side and try in on the passenger and see if it works then. Does this make sense? Can I do this without disconnecting the battery?
Then if that doesn't work could I then swap the switches over?
Thanks
d
So could it be
Thanks
d
austinlandroverbill
Mar 13, 2015 12:54 PM
MurphyPeoples
Mar 11, 2015 06:01 PM
