Rear storage unit.
Old Jul 9, 2021 | 04:28 AM
loanrangie's Avatar
Default Rear storage unit.
I did start this a while ago but wasn't sure how i wanted to execute it, originally was going to use 25x25mm aluminium tube with plastic connectors but it would use a lot space since you can only make square a rectangular shapes.
Decided steel was a better choice as i could make any shape i needed and use smaller tube, 13m of 13x13 x1.8mm found its way onto the roof rack and i made a start the next day.
I already had the plywood for the top so mocked up the height i would need to clear my fridge, taking into account that the Disco floor slopes to the rear with a drop of about 25mm front front to rear.
Also needed to tilt the fridge slide back so once fully extended it would clear the lower tailgate, i made up the base frame but soon realised that to get the rigidity i needed i would need more steel or even go up a size in tubing.
Luckily i kept an off cut from an old roof rack that a mate and i went halves in years ago which had just enough long pieces to remake the base frame, i then cut down the other frame to become the top frame.
Slide is one i made for my old D1 and i just based the rest around it,on the left i will make a lipped tray on slides with a large removable plywood box.
I will be using turn buckles onto the tie down points to secure it since the frame sits right over the bolts, i made it so it can be removed easily and is quite light.
Old Jul 9, 2021 | 04:35 AM
loanrangie's Avatar
Tested out over a few days away for a mid winter camp.
Old Jul 9, 2021 | 08:47 PM
DakotaTravler's Avatar
Wow, thats really nice! I made a module for camping too, but took a different approach as is only sit on one side since I sleep in the truck. Besides a fridge, it has a stove, sink and storage also. Handy to have when camping and modules like that are great since you are not modifying the truck permanently.
Old Jul 11, 2021 | 03:53 AM
loanrangie's Avatar
Yeah it had to be able to be removed easily. I don't like the traditional double drawer units with fridge on top , not very practical and the drop fridge slides are bulky and expensive. This fits with how i use the vehicle and can be changed easily, i will make a chuck box style kitchen that fits on a tray and also a large plain box for when i don't need the kitchen. Hoping to incorporate some power sockets and switches, there is also space behind the fridge that will fit a 20ltr water container with maybe a small pump and a water outlet at the front.
RossN99
Dec 1, 2023 12:13 PM
redwhitekat
Jun 26, 2021 03:17 PM
escott16
Apr 2, 2020 12:52 PM
ge234
Mar 30, 2019 12:39 AM
dtmbinb
Feb 25, 2019 11:40 AM
