rear sunroof
You do NOT have a rear opening sunroof. You have two moon roofs that share the same massive piece of glass. I'd look to see if it's cracked or if there is water coming in from the side or maybe the 3rd brake light. Where is your leak specifically? As in, where is the water ingress happening and where does it pool up? Jump up on the rear tire and look at the glass to see if it's damaged. Or use a step ladder.
loanrangie (11-11-2021)
