rear sunroof
I THINK I have a rear opening sunroof? I have a 2005 Land Rover LR3. I have a screen for it. I am "ASSUMING" it opens. I have a huge leak and I think it is coming from the roof. Can someone help me on this. How do I open it? Close it?
TIA
TIA
You do NOT have a rear opening sunroof. You have two moon roofs that share the same massive piece of glass. I'd look to see if it's cracked or if there is water coming in from the side or maybe the 3rd brake light. Where is your leak specifically? As in, where is the water ingress happening and where does it pool up? Jump up on the rear tire and look at the glass to see if it's damaged. Or use a step ladder.
Where is it leaking? If it is the C pillars (behind the rear doors and soaking the carpet around the middle row seats) it may be the rear drains for the front sunroof (the one that DOES open).
