Rear sway bar bushing
I have a rear sway bar that is clunking. After checking it is moving pretty freely side to side. Does this call for just a bushing replacement or is it recommended to change out the linkage as well?
Also, any need for an alignment after the fix?
tks
tks
Sway bar links and bushings are two separate service items. The bushing generally last about 100k miles, maybe a little less or more deepening on how driven. Sway bar links tend to take more abuse and fail quicker in areas with rough roads. Just do the bushings and check the links for play. If they have play, then replace. They do not have to be replaced in pairs.
