Which rear upper control arms to buy?
Old Apr 6, 2025 | 03:05 PM
Gordo51's Avatar
Default Which rear upper control arms to buy?
While doing my recent brake job I investigated a clunking noise at the back and discovered my upper control arms inner bushings are worn out so I need new bushings at the least. I have a couple questions:
1. Are aftermarket control arms, complete with bushings, just as good as pressing new LR bushings into the original arms?
2. If you bought aftermarket arms with bushings, which brand did you go with and how many miles on them?
3. If you can get the nuts off the bolts do the bolts push out or are they usually rusted tight in the bushings?
Thanks fir any info,
Gordon
Old Apr 7, 2025 | 07:02 AM
lenzda's Avatar
I just replaced all my control arms (front and rear). The back uppers were the only ones I had to cut off. The forward facing bolt was rusted to the control arm all the way through the bolt shank. It took 2 carbide saw-zall blades to cut them out.
I ended up installing Delphi control arms from rockauto. Hopefully I get 5+ years out of them.
Old Apr 7, 2025 | 10:10 AM
Gordo51's Avatar
Thanks for the reply. I have been considering the Mevotech version. I watched the Atlantic British YouTube video and it doesnt look as bad a job as I first thought. I do have all the needed tools.
Old Apr 7, 2025 | 03:14 PM
lenzda's Avatar
Tool clearance is the main issue. I was able to use a high torque electric impact driver to get most of the bolts.
RickyN29
Jun 13, 2018 11:54 AM
jft1428
Mar 22, 2018 10:25 AM
AdrenalinPlease
Nov 20, 2017 10:32 PM
asv4k8
Mar 7, 2011 07:29 PM
samsly
Jan 27, 2006 12:14 PM
