Red blinking height marks on 4x4 screen
Old Apr 19, 2019 | 12:41 PM
houm_wa's Avatar
Is there a fault indicated?
The fix involves re-calibrating your suspension. If you don't have an IIDTool by Gap Diagnostics, you'll need one. Then you can go about re-calibrating your EAS.
If there is a fault indicated, then yes disconnect your battery to clear it. This should at least get your EAS back up again, but it is not a fix to your issue, just a temporary way to get your back up to normal height.
Old Jul 17, 2022 | 05:15 PM
Luisovsa's Avatar
Default Suspension Fault
Hi everyone, we were driving today and got a message stating Suspension Fault, and so I clicked in the 4x4 to see if anything popped up and we saw the lights/dashes above the tires flashing. Shortly after the car warned us about lowering speeds to 30mph and the last .5 mile drive was horrible as the car suspension was not working. Any idea what this is?
Old Jul 17, 2022 | 08:15 PM
DakotaTravler's Avatar
Start a new topic, with codes.
Old Aug 6, 2024 | 06:15 AM
Rogant's Avatar
Originally Posted by mazzygirl
I have owned my 2009 Range Rover since 102,000 miles. I replace the left front ride height sensor 1,000 miles ago and have and no issues with the warning I was having of the suspension fault. After leaving my car parked for a week (which is not unusual, it's only driven 500 miles/month), the front suspension will not raise. The front right tire on the screen flashes red for a short period. The suspension never raises. Fixes? I think I'll try disconnecting the battery to start.
Re: did this work for you disconnecting the battery having the same issue with my 07 supercharged didn’t drive it for a week or 2 either and now the front won’t lift but my miles for the trip reset I seen so I’m thinking maybe something happened with the battery
Curtis Hudson
Nov 29, 2017 07:38 PM
ljdiscovery
Oct 17, 2016 01:40 PM
Volkov
May 21, 2015 07:25 AM
Land Rover 4.4
Jun 12, 2011 07:45 PM
Manicoti
Jan 23, 2011 09:22 AM
