Replaced compressor and it wont run
Old Mar 26, 2022 | 01:46 PM
  #71
Flyfishinguy85's Avatar
This thread is a novel, so I am not going to read back to start and try to find what I am going to ask if you dont mind.
But each compressor requires a software change in the truck. Meaning when the hardware is changed, one must change the software.
1 - With the original issues, was that truck equip with an AMK originally and worked fine until it did not?
2 - Did you ever verify the software was set for AMK?
3 - When switching to the Hitachi, did you change software?
If you never made the software change to the Hitachi and its working, I have to think that is what the software was always set to do the AMK would never work right, it was "out of spec" as far and the computer was concerned.
it did have the amk when I bought the rover. Previous owner said, bought new amk 6 months ago from a dealer for a crazy price. Was updated to amk software and i bought a gap tool and verified. Even switch to Hitachi and back to amk to make sure it would over write if there was a glitch. Plugged in the junk yard Hitachi and reflashed to Hitachi and started the rover. Ran full cycle and got to full gallery pressure 2x faster then I ever got any of the Amk's ( if and when they would choose to work)The amk motors seem fine. The air dryers are complete trash. At least the 3 I tried. One 6 month old and 2 brand new...
Old Mar 26, 2022 | 01:49 PM
  #72
DakotaTravler's Avatar
Wow... kinda crazy. Looks like you finally have it sorted out, what a fricken pain and cost!!
  #73
Also, even tried to run amk off Hitachi software to see if it would make a difference... It did not.
Old Mar 26, 2022 | 01:51 PM
  #74
so much time wasted on shipping back and forth. Pretty sure I learned a few new words through out this adventure haha
Old Mar 26, 2022 | 01:53 PM
  #75
When you swapped to the Hitachi, you would have had to remove some extra pipe(s). Were any damaged? There is one for sure that would get yanked with the swap, ran over to the outside of the AMK from above it. I can only think that in some way the AMK conversion was done wrong???
Old Mar 26, 2022 | 01:57 PM
  #76
the conversion was routed properly. I need to plumb everything back to install they hitachi. So not done yet.. So close lol
Old Dec 29, 2022 | 11:20 PM
  #77
Thomascblethen's Avatar
3rd Gear
Default Suspension fault red and special programs off
What color is the dash icon? Red or yellow. And exactly how fast, like instant or after a few seconds? The obvious is fuses and the like. Also is it still at off-road height?
need some help replaced center valve block and compressor and both 70 amp relays checked fuses and am stumped my river is on the bump stops I can’t get it to raise
Old Dec 30, 2022 | 09:40 AM
  #78
Thomas - do you have sensor extension rods installed. If so, it will not raise form bump stops. You have to jack up the front and rear a bit to get the sensors back into readable range. If not, then we need codes.
Old Dec 31, 2022 | 12:33 AM
  #79
3rd Gear
Default Suspension
So I jacked it up and it worked we had to toy with the computer a bit but still getting a red suspension fult says it’s having connectivity issues with the ecu for the air system so I think it’s time for a new one of those but also threw a ride night sensore code but ima home it leveled its self out even with a red light and seems to be working I’m super confused
Old Jan 2, 2023 | 07:17 PM
  #80
A red indicator in an apparent working system could be the suspension stuck in build mode or stuck in tight tolerance mode.
doxster22
Feb 12, 2025 05:07 PM
Darren Felber
Jul 25, 2020 07:26 PM
Lr3edm
Jan 11, 2020 08:56 AM
DbDet
Aug 7, 2019 08:26 PM
