Replaced Thermostat Housing - Engine Overheating Still
Old Oct 16, 2013 | 09:45 AM
Bravhefen's Avatar
Default Replaced Thermostat Housing - Engine Overheating Still
06 LR3 - Thermostat housing had a hole in it. I replaced the entire part with a new one that came with a factory installed new thermostat. The install went fine, however I had a very hard time getting the cooling lines to preasurize once up and running. I ended up taking it to a shop and had the system flushed. Drove fine for one day, then started overheating again. Also my heater doesn't get hot. I can smell hot coolant but nothing is leaking.
Any help is appreciated.
Old Oct 16, 2013 | 12:05 PM
Bleed more air out of system and top up coolant.
Old Oct 16, 2013 | 09:33 PM
roverguy7's Avatar
What did the inside of the plastic housing look like when you took it off, and how much did it overheat before replacement?
I have seen that housing completely melt on the inside and get plastic all throughout the system creating blockages.
Old Oct 17, 2013 | 12:56 PM
Bravhefen's Avatar
Yeah, I'm concerened that there could be some kind of blockage. I have a steady stream of coolant returning to my reservior, so If I do, it's not a complete blockage, but I do experience some overheating spikes. I have no engine light indicators or errors. The vehicle is running fine. (other than overheating) which I can return the tempature to normal by blasting the heater, but the heater doesn't blow hot air.
I get to and from work ok, but I'm affraid to drive it any further for fear of damage.
rzuluaga
Dec 18, 2015 11:54 AM
Trickymonk
Apr 25, 2012 10:45 AM
Travelor
Jul 8, 2011 09:58 AM
heromanLSU
Nov 4, 2009 12:09 PM
