Replacing Oxygen Sensor
Old Sep 24, 2012 | 06:40 PM
canbuster's Avatar
8th Gear
Thanks everyone. After 170 more miles of driving on the freeways and around town, the CEL went away on its own.
By the way, with the non-oxygenated 88 octane for $3.99/gal, I'm getting about 10% better gas mileage than the Costco 91 with up to 10% ethanol for $3.79/gal. So in my case it's worth it to pay ~5% more to get ethanol free gas. With the higher elevation in Utah, I assume 88 octane should be fine.
Old Aug 27, 2018 | 08:12 PM
dparizek's Avatar
So if someone _does_ need to change the sensors, any advice on getting them unplugged with such little room to reach into them? That was how this thread started... the original noted he could potentially get them unscrewed but how to unplug the connectors when you can at best reach one hand to them?
Old Aug 28, 2018 | 07:40 AM
abran's Avatar
If it’s the Driver front you are struggling with, unbolt driveshaft at rear and push aside, gives you just enough room.
Old Aug 28, 2018 | 08:36 AM
dparizek's Avatar
Default Thanks!
Thanks! I was hoping someone knew a trick to avoid having to undo the drive shaft... but good to know.. just do it and get it done.
Old Aug 28, 2018 | 10:07 AM
abran's Avatar
I’ve learned to stop trying to cheat and just remove sh$t.
Philip Chan
Nov 3, 2019 08:06 PM
OgEric
Dec 23, 2018 10:47 PM
klandrover
Apr 5, 2016 12:50 PM
Enrique5
Jul 2, 2012 10:22 PM
bonedoc
May 1, 2007 06:49 PM
