ride Module reconfiguration?
Old Jun 3, 2016 | 04:22 PM
CATTIVA73's Avatar
Default ride Module reconfiguration?
Anyone knows how to reconfigure the ride module after replacing the susp. air compressor with same Hitachi model ?
will a reg. mechanic shop be able to do it? or does it need to be done by Land Rover Dealership Only???
closest dealership is about 2 hours from me ...
Thank you
Old Jun 3, 2016 | 04:29 PM
drowssap's Avatar
Question are you just replacing the compressor or are you going from springs back to air?
If just replacing the compressor it is plug and play, if the latter then you will need to reset the bcm for air and not coils.
You won't need a dealer but you will need someone with one of a 1/2 dozen machines that can do it.
Thank you
Old Jun 3, 2016 | 04:31 PM
Big Jim Swade's Avatar
Have you replaced the compressor already? I wouldn't think you would have to do anything, but I've never replaced the compressor. I replaced my air springs a couple years ago and I didn't have to anything because of that change.
Old Jun 3, 2016 | 05:40 PM
Best4x4's Avatar
Isn't the SLS option stored in the SLABS unit?
Old Jun 3, 2016 | 06:41 PM
That's what I thought. That's why I don't think you need to do anything other than plug the new compressor in.
Old Jun 3, 2016 | 09:50 PM
jafir's Avatar
Are you talking about an LR3/D3 and not a D2?
Old Jun 4, 2016 | 05:39 AM
CATTIVA73's Avatar
Default New compressor
I just replaced the compressor on the LR3 but still susp. amber light now its red...codes are: U421-41, B1A00-46, U0155-87, C1A13-64 after replacement.
When I called Land Rover dealership they said Module needs to be reconfigured ..?
Old Jun 4, 2016 | 07:36 AM
jafir's Avatar
I've moved to the LR3 forum.
The module should only need reconfigured if you change type from hitachi to AMK. There are updates to the hitachi software, but even if it's running old hitachi software it should still run. Does the scanner not give text for those error codes?
Old Jun 4, 2016 | 08:05 AM
ljdiscovery's Avatar
When I swapped mine it did not require any update. Try deleting all codes and see if they return. Good luck. Phil
2005 LR3
2006 Range Rover Sport
Priors
1999 Discovery I
1999 Discovery II
2001 Discovery II
Old Jun 6, 2016 | 11:31 AM
CATTIVA73's Avatar
Default issue resolved...hopefully ;)
AS ...it turns out the "new" compressor had a bad valve that caused the code C1A13-64 .
As far as the other codes YES the Control Module requires to be recalibrated/programmed to the new component ..even if its the same model compressor.
Now All the other codes are cleared.
Im just going to have the shop replace the valve with a better one sold from Land Rover Dealer to clear the C1A.. code and everything should be happy
So for future reference: New compressor = New programming no matter what.
The recalibration was not that expensive ($50).
I wanted to thank you guys for all your help you guys rock!
