Roof glass removal
Old Nov 4, 2022 | 05:44 PM
keninnc's Avatar
Default Roof glass removal
2006 LR3
My roof glass is cracked but does not leak.
I'm tempted to replace it from an LR3 at a close by salvage yard.
I've pulled the headliner down before so I'm not worried about that.
Has anyone attempted this?
Any tips?
Old Nov 4, 2022 | 05:55 PM
DakotaTravler's Avatar
It can be done, but it is a pretty large panel. Your does not leak probably because only the upper or lower pane is cracked. Its a double-pane setup, two very thin sheets.
Old Nov 5, 2022 | 10:19 AM
Rufflyer's Avatar
Just went through that. Mine leaked after getting hit by a BIG rock in the freeway. Dealer charged $4980.00 to replace. Yes the head liner has to come out. I turned it into my insurance so I should just be out my deductible. BUT, if it had not been leaking........... I would have sprayed it up with flex seal as a back up and left it in.
Your car do as you want, but there is a reason the labor was $2200.
Let us know how it turns out.
Jeff
Old Nov 6, 2022 | 01:02 PM
houm_wa's Avatar
Sounds like you got screwed, @Rufflyer . I got mine replaced last year. I paid $500 (insurance deductible) but it would have otherwise cost under $2500 total. I saw all the costs. Best to find an independent shop that can do it. Also, the headliner doesn't need to be removed. That's true for the D2 but not the LR3.
Old Nov 6, 2022 | 02:28 PM
NJOverland's Avatar
Yeah, because Land Rover is on crack with their repair prices. That's the only reason. They also wanted $9000 to fix something my gap tool fixed.
Old Nov 6, 2022 | 05:27 PM
Rufflyer's Avatar
Default I only paid the deductable
I did not actually get screwed.
I went to the 5 places recommended by the insurance agent and none of them wanted to do it. I told the agent I was taking it to the dealer, they said OK just submit the bill when done. Well it the big issue was I had to wait because it was delayed 3 weeks to get the glass from the UK.
Money aside, I still believe that it is not leaking, just leaver it alone.
Jeff
Old Nov 7, 2022 | 07:52 AM
keninnc's Avatar
Well I learned removing the glass DIY is almost impossible.
I believe you need the specialized tool that windshield glass repair shops use. The kind that has a crank and moves the wire around the perimeter of the glass to cut the seal. The inexpensive tool to pass a wire through the seal and have two persons cut the seal would be a very difficult task.
I was hoping to use a multi-saw tool from the inside to cut the seal but this did not work.
I'm not sure how the glass would be removed from the outside without damaging the paint.
My glass does not leak and I'm leaving it alone. I wanted to at least give it a try and see if I could do it.
Old Nov 7, 2022 | 07:41 PM
SeattleDriver's Avatar
JLR factory procedure just states to cut the sealant using a glazing knife or cutting wire and to lift out using suction cups. No need to remove the headliner.
MAPC
Nov 15, 2023 05:08 PM
Wolfbread
Apr 21, 2022 01:01 PM
Charliegeosci
May 18, 2021 12:15 PM
krick3tt
Nov 11, 2020 08:14 AM
Mai-ILLINOIS
Apr 26, 2017 08:33 AM
