Rover LR3 ground location C2922-1 ?
Old Aug 25, 2021 | 07:53 PM
DakotaTravler's Avatar
Default Rover LR3 ground location C2922-1 ?
C2922-1? Connector? Just trying to trace fuel pump wiring. Positive I physically know well, but the ground is ran some place else. I dont have a connector location chart in my RAVE files. This ground is shared with upper gate actuator, fuel pump, fuel burner and a brake pad wear sensor. Just want to locate and inspect the grounds.
Old Aug 26, 2021 | 02:54 PM
Rufflyer's Avatar
C2922 is in the left rear just in front of the tail light. It is on the large bundle coming up from the bottom part of the body running up to and through the D pillar I will try to get a picture later to help narrow it down some more.
C2922-1 means it is in pin 1 location (but you knew that)
Or atleast it is on an LR4
Old Aug 26, 2021 | 07:47 PM
Interesting. There must be another connector in between since the frame harness would have to couple to the body first. Will poke around a bit tho, thanks!
Edit: Found it on anther page. C0390-10 C0376-10 - that I think is the group of body/frame connector behind rear airbag. Pin 10 it what I will look at.
Old Aug 27, 2021 | 05:57 AM
Rufflyer's Avatar
C0390 and C0376 are both co-located behind the left rear cargo trim piece just above the left wheel hump
Old Aug 28, 2021 | 06:56 AM
Rufflyer's Avatar
DakotaTravler:
See if this attachment helps
Old Aug 28, 2021 | 09:43 AM
That works, thanks much!
DakotaTravler
Mar 30, 2021 08:33 AM
lawsonmahoney
Mar 21, 2021 03:06 AM
RichardT
Apr 25, 2014 11:24 AM
ReyG
Jan 9, 2014 08:24 PM
Rearden Steel
Feb 21, 2011 08:26 PM
