Rusted brackets
Old Mar 19, 2023 | 04:33 PM
Viking1's Avatar
Default Rusted brackets
Hi all,
I hate rust!
Recently I was under my 2005 LR 3 and notice 4 rusty brackets or securing clamps holding 2 approximately 3/8 “black hoses in place against the chassis vent lines I think ? Anyway I’m trying to identify these specific clamps . Any help is appreciated Thankyou.
Old Mar 19, 2023 | 08:59 PM
P-Bod's Avatar
Are you looking for these rusty clamps on the a/c lines? Mine are all rusted out too on my 07. I can’t find them separate from the whole new a/c line assembly.
https://www.ebay.com/p/1111270068
Old Mar 19, 2023 | 10:02 PM
DakotaTravler's Avatar
See here:
https://landroverforums.com/forum/lr...-straps-90890/
Old Mar 20, 2023 | 09:21 PM
Viking1's Avatar
Default https://parts.jaguarlandroverclassic.com/jup500050-clip.html
Brackets can be purchased at https://parts.jaguarlandroverclassic...0050-clip.html
good luck getting nuts off the bracket studs.use a small grinder best bet.If you snap them off drill a new hole in the chassis using a small right angle drill and buy new stainless self tapping screws and washers.also spray the new brackets and undercoat them after. Good luck
Old Mar 21, 2023 | 01:00 AM
loanrangie's Avatar
Get some galvanised steel flat bar and bend in the vice, drill a hole and job done.
Old Mar 21, 2023 | 11:43 AM
Viking1's Avatar
Default Yes that will work for sure:)!
great advise however I like the challenge of finding the original brackets thanks for the common sense approach.
Question: Are those AC lines under the rubbertex. Looks like a high and low pressure lines.
Ok small issue but resolved Photos show new AC lines and new brackets as well as OE part number and diagram part’s breakdown. I used stainless self tapping screws with a right angle drill The original nuts and tsp welded studs ng I just cut them Next week in a good day I will spray the entire undercarriage and exposed rust and metal with WoolWax to kill any rust spots as well as the internal chassis rails
Old Mar 21, 2023 | 12:53 PM
P-Bod's Avatar
Yes. Feeds the rear a/c along the frame, left side, near the air suspension compressor.
hell pie
Nov 22, 2023 09:24 AM
redwhitekat
Jul 15, 2020 05:19 AM
Bago
Nov 13, 2012 11:30 PM
Disco Fuego
Apr 30, 2009 06:28 PM
chakadog
Jul 11, 2007 11:03 AM
