Safe Battery Charger
#21
#23
The compressor has no need to run during an alignment, as the height should not be adjusting, and will change every reading and adjustment already made if it does.
It should not run without the engine running.
The power supply for programming is so keep battery voltage up to a safe level for module communication. Voltage will drop when everything is on and working when the key is turned on. I do not recommend trying to do anything, even just clearing faults, with the engine running.
IDS is a great tool, but can be a real pain to learn how to use correctly, if you have questions once you get into it, ask before playing around, as there is stuff that you can create issues by doing. Also note, you will not have the most up to date software, so some updates will still need to be done by someone that does, the big one that comes to mind is the software for the new AMK compressor.
#24
Yep. I didn't fully read the tsb. It says you can disconnect everything after placing the system in tight tolerances mode. So the power supply is just for the programming.
http://www.disco3.it/gallery/albums/...tting_Mode.pdf
#25
I'd be curious how you did it. I've had one for a year, and never got it to work. The software was bunk, and you can't download a new version. Perhaps I could get some tips/software... PM me..
I use the CTEK in supply, and it's important to use a charger because things may go wrong badly if the voltage drops. A lot of stuff needs to be done with the ignition switch on, and that draws a lot.
#26
carid
12-03-2014 08:42 AM
Mrmerlin
12-14-2010 08:21 PM
