Safety Tip - Working Under Rover with Air Suspension
Old Jun 11, 2018 | 02:31 PM
RickyN29's Avatar
Default Safety Tip - Working Under Rover with Air Suspension
Hi All,
Just a safety tip, if working under the vehicle, have a jack stand for safety. Supposedly the suspension will lock if a door is open but my early build 2005 does not. With two doors, hood, and hatch open...mine still auto adjusts. (Though will not accept a height change request with doors open).
I was changing lift rods, doors open, and sure enough, car came lowering down. Thankfully had stands underneath with me!
Pulling fuse 26 does seem to do the trick though.
SAFETY FIRST everyone!
Old Jun 11, 2018 | 06:13 PM
DavC's Avatar
This has been discussed before but any car should be adequately supported if you are under it. The door open function almost never works, and should never be trusted with regards to life safety.
Main fuse F26 is still the one to disable by hand, either pulling or using a switch. See: https://expeditionportal.com/forum/t....154622/page-4, essentially the same as Bbyer's old solution. Cabin fuse F35P is a subsidiary in that EAS system but F26 is main power.
22Dirty
Sep 19, 2019 12:01 PM
ninjaff21
Range Rover L322 (3rd Gen)
Aug 27, 2019 08:25 PM
Wilky1978
Mar 13, 2012 02:45 PM
pebbles
Oct 29, 2009 06:37 PM
Charles68
Mar 9, 2008 04:24 PM
