Seats and sunroof non-op
Did you ever figure this out? My 2005 had water issues as well. Driver side sunroof drain being the main culprit. I too am having an issue with my sunroof not working (seat memory works though and displays on dash when I set a position).
From my research the Rain Sensor, Seat Memory Module and Sunroof Module all work off the LIN BUS. Seeing your seat module and sunroof aren't working, I wonder if your issue and mine are similar. I verified I am getting power to my sunroof module and verified the motor is good, so I'm hoping there is corrosion or something on the LIN BUS connections. I believe pin 7 (grey) and pin 8 (red) at the Seat Memory Module connector under the drivers seat are the LIN BUS wires. I still need to trace mine and check for corrosion.
I think I am having a similar issue. Any news on repairing this problem? At first I noticed my sunroof wasn't working. Then I discovered the driver seat only moves in increments. I also have seen my power mirrors, steering wheel adjustment and rain sensor is not working. One day I noticed the driver seat moved in one continuous motion and thought to check the sunroof and it worked as well. I have discovered that when one works they all do so all these items must be connected somehow to whatever is causing the issue.
Thanks, I dont think that is my issue. The drivers seat always has power it just moves in increments and sunroof , mirrors, steering wheel and rain sensors do not operate. However, i have discovered by clicking the lumbar support switch back and forth rapidly I can usually get everything to work temporarily. I know that sounds weird but one day i went to adjust the lumbar support and saw the seat and steering wheel move up and back when I shut the vehichle off so I thought that's strange maybe the sunroof works and sure enough it did.Does this new info provide any clues to what could be the issue or do you think it still may be that splice.
akilbrid
08-20-2017 12:18 AM
booper169
11-09-2010 09:10 AM
