Should we have Fuel Injectors cleaned?
Old Jan 22, 2021 | 10:36 AM
Athana's Avatar
Default Should we have Fuel Injectors cleaned?
Hi..any benefits or dangers to having our Feul Injectors cleaned? LR3SE V8 2006 186,000 milesThank you
Old Jan 22, 2021 | 02:20 PM
pagoda's Avatar
Never heard of anyone doing it (removing and cleaning) unless they fail. I can recommend a can of BG44K every 10K or so. I don't use injector cleaner on my vehicles, but based on the reviews of that stuff I have been using it for a few years. No idea if it makes a difference to be honest and the interweb is chock full of views about injector cleaners/additives, etc.
Old Jan 22, 2021 | 05:41 PM
DakotaTravler's Avatar
I add Seafoam every so often, the downfall of using zero ethanol premium fuel is that it does not keep things as clean as it could be. So I tend to agree with pagoda, the injectors should not need direct cleaning unless there is a reason. I think just running cleaner a couple times a year makes a good enough difference. Key is to add the cleaner, run vehicle for a while to make sure cleaner is in the fuel at the injectors (this can mean over a 10 mile drive, lots of fuel stored in those lines!) then let sit overnight. Also I tend to go pretty concentrate, a little over a quarter tank for one can.
Old Jan 22, 2021 | 06:17 PM
houm_wa's Avatar
Default Cleaning fuel injectors...
Don't see how it can hurt.
Old Jan 22, 2021 | 09:06 PM
planetspacerover's Avatar
Seems the benefit would be cleaner injectors.
I use BG44K every 15,000 miles. I believe that's the official recommended interval from Land Rover.
Additionally, there is a BG Service which cleans the injectors at the rail. It is my understanding this is a good and necessary service for the LR3 to prevent injector clogging. When I had it done at a shop it was >$400.
Old Jan 22, 2021 | 09:35 PM
canamrotax's Avatar
4wd High
I just run a tank of premium fuel about one in ten tanks. Works for me.
Old Jan 23, 2021 | 08:47 AM
The trucks require premium on the 4.4. And premium gas does not clean better, in fact is usually cleans less if it lacks ethanol...
Old Jan 24, 2021 | 11:48 AM
canamrotax's Avatar
4wd High
The premium fuel I choose has heavy detergent content (by comparison) and I have used it to clean out old snowmobiles and motorcycles too.
Old Jan 24, 2021 | 11:50 AM
canamrotax's Avatar
4wd High
https://www.shell.ca/en_ca/motorists...-gasoline.html
Here is a link to the premium fuel I use, it has more detergents than the lower cost fuel I usually run.
Old Jan 24, 2021 | 04:27 PM
Cool story, still need to always run premium in the 4.4....
Frank4
Jul 8, 2020 04:50 PM
TRIARII
Dec 10, 2016 02:58 PM
Willie00d2
Feb 28, 2010 08:11 AM
modem7890
Feb 11, 2008 09:31 AM
