Significant leak…(video and pics)…
Old Nov 10, 2025 | 07:56 PM
cavenger123's Avatar
Default Significant leak…(video and pics)…
I am getting a leak when the coolant system is under pressure Where do you guys think this is coming from? The oil cooler? It’s not the oil cooler lines. Those are farther down. Is it possible it’s above?
Old Nov 10, 2025 | 11:06 PM
Default Another video…
Old Nov 11, 2025 | 07:30 AM
DakotaTravler's Avatar
I hope that is not just water. My guess is the water pump is leaking and tracing its way down, pretty typical.
Old Nov 11, 2025 | 07:40 AM
It’s coolant. Why are you saying you hope it’s not just water?
It seems like it’s a strong leak to be coming from up there but you could be right. I have replaced the water pump twice in two months. First one was an Amazon cheapo, second one was a Autozone Duralast. I may just break down and buy Atlantic British. But I am not sure it’s the water pump just based on that fast flow but I confess leaks are a challenge for me.
Old Nov 12, 2025 | 08:39 PM
you were right. It’s definitely the water pump. I got a new gasket and it’s still not sealing. I really don’t know what I am doing wrong. Does it near rtv sealant? I did not put any on. It seems to be coming from the bottom. I tightened the bolts as tight as I feel comfortable. I don’t have a torque that goes to 10nm.
Old Nov 12, 2025 | 08:50 PM
loanrangie's Avatar
10nm is not much, i would definitely be using a sealant on it.
Old Nov 12, 2025 | 09:13 PM
I have no idea other than I had read you shouldn’t use sealant with a plastic gasket. But that’s just the internet for you.
Old Nov 12, 2025 | 11:07 PM
loanrangie's Avatar
Cant say i've seen a plastic gasket on a pump before, the TDV6 doesn't have a gasket on the mating surface but does have an o-ring on part of the pump that's inserted into the block.
Maybe need to clean the surface up a bit more.
Old Nov 13, 2025 | 05:56 AM
sorry. It’s hard rubber.
malibumike
LR4
Jul 17, 2023 01:56 PM
Ricky K
Feb 11, 2022 03:32 PM
DISCOFETA
Jan 9, 2022 11:00 AM
Discorama
May 1, 2021 07:57 AM
Dherna
Jun 16, 2019 01:57 PM
