Squeaking noise when driving.... help please
Old Aug 22, 2013 | 11:23 PM
jv3x3's Avatar
Default Squeaking noise when driving.... help please
Hi all. First post. Dire need of some timely expert wisdom
Car details: 2007 LR3, 21k miles
Issue: When driving (generally speeds between 30-80 MPH) my land rover will occasionally start letting out a persistent squeaking sound. Its most noticeable with the windows down and radio off (duh to the radio part) and fairly loud and constant. If it is squeaking and I apply the brake it will stop. It will not stop if I simply let off the accelerator and do not brake.
I tried doing what searching I could to find posts with similar problems and the most common things I heard mention was the driveshaft needing to be replaced (and that I should do it now or I am risking my tranny... ouch trip this weekend planned ) and a belt/pulley issue. Based on the details I couldnt be sure either matched what I had.
Anyone have any ideas what it is? Anything I can test or look for? Am I risking screwing something up worse by driving it?
Really bad timing as I am supposed to head out to the family cabin this weekend for a get together (roughly 4 hour drive each way). So really appreciate all input here.
Old Aug 26, 2013 | 05:11 PM
unseenone's Avatar
Wheel Bearings, Belts, Belt tensioner, CV Joints, Diff, vacuum leak, Brakes, Rotors...
How many ML is left on your brake pads.
Hard to say if you can drive it or not, because we don't know what's wrong yet, is it just annoying, or is there another issue, heating up, running cold, roaring, etc.
more sound identification videos that are pretty neat.
jjvd21 - YouTube
If you have no idea where to start, you might consider a visit to a dealer or a LR Independent.
Old Aug 26, 2013 | 05:42 PM
dusty1's Avatar
if its going away when you brake, could be hub but i would lean towards brake caliper sticking. change pads if needed, clean up calipers while you are in there and grease them before re-installing. if its hub you will likely feel the slack when you are up on the jack.
Old Aug 11, 2020 | 08:06 PM
Chelsea89's Avatar
Default Same problem
Hi, I’m currently having the same issue and was wondering if you found the root cause. I’m taking a chance as I see your post is quite a bit older. Thanks in advance @jv3x3
Old Apr 9, 2022 | 12:12 PM
shortbread69's Avatar
Did you get an answer / diagnostic?
FLA Rover
Sep 13, 2013 11:10 AM
Green Manual Disco
Sep 7, 2012 02:18 PM
thehun
Jan 25, 2011 03:16 PM
CCRover98
Jul 14, 2009 09:58 AM
MARGE
Oct 16, 2006 12:21 PM
