SRS Deployment Control 1 Resistance Problem
Old Sep 12, 2019 | 02:31 PM
prossett's Avatar
Default SRS Deployment Control 1 Resistance Problem
Recent purchase, just fixing and working through the codes - got an SRS light on.
Code reads B00002 - Driver's frontal stage 2- deployment control. Comes back on when cleared.
With engine running, datastream shows me exactly where the problem is but I don't know where to check physically. Which connector, where?
Deployment Control 1 Resistance - 10.24 ohm
Deployment Control 2 Resistance - 2.32 ohm (within spec)
Deployment Control 3 Resistance - 2.32 ohm (within spec)
So I know that Control 2 and 3 are fine, and the problem is with Control 1 - but where do I check that?
Are Control 1, 2, and 3 in different locations?
Old Sep 13, 2019 | 01:51 PM
abran's Avatar
Its the clock spring.
Old Sep 14, 2019 | 02:28 PM
prossett's Avatar
Thanks - yes, makes sense. I've been looking at the replacement how tos and it seems pretty straightforward. I'll give it a shot.
Old Nov 11, 2019 | 02:43 PM
Fishbone's Avatar
5th Gear
Default Deployment Control resistance
Does anyone know which deployment controls correlate to corresponding #'s. Having a resistance issue with control 2 but have no clue where that is located.
Old Nov 11, 2019 | 10:08 PM
prossett's Avatar
For control 1, it was in the clock spring, as was correctly advised.
Replaced that, and the SRS light went off.
I'm going to guess also controls 2 and 3 are part of the clock spring. It was a cheap and easy replacement, so worth the guess.
Old Nov 11, 2019 | 10:14 PM
Fishbone's Avatar
5th Gear
My code thrown was B0010 passengers side stage 1. And as we know there is a lot going on with that passengers seat.
Old Feb 12, 2023 | 02:18 PM
raynielw's Avatar
4th Gear
I am getting the exact same code. B0010-1b Passenger's Frontal Stage 1 - Deployment Control 2 Resistance High. Were you able to resolve it and if so what was the fix?
Old Feb 12, 2023 | 11:26 PM
Fishbone's Avatar
5th Gear
Hey Ray,
I was unable to find the issue and gave up looking so now I just deal with the intermittent airbag light. She comes and goes.
Old Feb 13, 2023 | 01:33 PM
raynielw's Avatar
4th Gear
Hey Ray,
Ahh okay. Will let you know if I’m able to somehow find a solution. Appreciate the response!
Anthony Frantzis
Dec 22, 2018 04:18 PM
grizzdog50
Nov 25, 2014 12:08 AM
