Still a leaky ship...
Old Mar 1, 2022 | 06:11 PM
Oceanguy33's Avatar
Default Still a leaky ship...
Hmm..
I thought I'd taken care of everything you were supposed to with water ingress. I made sure the intake vent/cowl was covered properly (this was a leak - confirmed by a wet cabin filter - fixed that). I pulled off the A pillars - they had not been repaired so I took care of the last hole and then RTV'd the other fixing holes. The drain pipes for the sunroof look good - can confirm they have been replaced and that they are not blocked.
Yet still, after significant rain in the NW I have water in the lower channel (where the loom sits). Not a lot, but still enough. From what I understood, there is really only three places that water gets in - and I looked at these. There seems to be no leak from the rear drains either (and the back channel is not wet). The carpet is not soaked so the water has been contained to the channel.
The only thing I can think of is the sunroof drain possibly being cracked or disintegrating and letting in a drip-drip-drip. But I can't tell that unless I pull it - which I don't really want to do.
Any other thoughts?
Old Mar 1, 2022 | 07:22 PM
houm_wa's Avatar
I would take the time to attach a shield over the pollen filter box so that any water getting past the cowl (even if it looks fine) doesn't get into the cabin.
Old Mar 1, 2022 | 07:25 PM
elemental_garage's Avatar
Blow out your ac condensation lines too. If they're backed up like mine were it'll leak under the carpet just like a sunroof drain backup would.
Old Mar 1, 2022 | 07:49 PM
Oceanguy33's Avatar
done and done. I even made sure by running some water off the cowl to make sure
Old Mar 1, 2022 | 07:50 PM
Oceanguy33's Avatar
Originally Posted by elemental_garage
Blow out your ac condensation lines too. If they're backed up like mine were it'll leak under the carpet just like a sunroof drain backup would. https://youtu.be/96lnAs-QcVs
have checked these. Not blocked. .
Old Mar 1, 2022 | 07:53 PM
Are your sunroof drains blocked at the top?
Old Mar 1, 2022 | 08:25 PM
SeattleDriver's Avatar
The sunroof drain lines can dry rot, allowing some water to seep into the car while still draining most water. Short of removing panels I’m not sure how you can rule this out.
Old Mar 1, 2022 | 08:45 PM
Oceanguy33's Avatar
Yes, this is my concern.
I know I checked the drivers side elbow and it was fine.
I will check again once I test the a pillar to make sure nothing was leaking in from there.
Does a leaking elbow wet the carpet or does it drip straight down to the wheel well?
Old Mar 1, 2022 | 09:32 PM
Blackngold77's Avatar
If it's not fully rotted or detached it can do both. Fully detached will leak only into the floor boards.
Old Mar 1, 2022 | 09:53 PM
It definitely will soak the carpet eventually.
Philip Chan
Feb 8, 2020 09:04 PM
Cjlr3
Nov 22, 2019 08:32 AM
CATTIVA73
May 23, 2016 06:19 PM
bullhead
Jan 19, 2013 02:49 PM
bustedwheel
May 16, 2011 01:56 PM
