Stupid question time - inner tie rod ends
Old Mar 29, 2018 | 04:35 PM
DakotaTravler's Avatar
Default Stupid question time - inner tie rod ends
New Lemforder parts came today. I know the outside tie rod ends are the same part. The inner rods are different part numbers. I suspected different threads for whatever reason. But maybe that is not the case? The ends that thread into the rack are very different in size. I hope that is the way it should be. Before I rip into the project, I would just like to confirm if this is normal or not. I do know there was a change in parts with a VIN split in 2009, but I have a 2006 LR3.
Attached Thumbnails Stupid question time - inner tie rod ends-img_3836.jpg   Stupid question time - inner tie rod ends-img_3837.jpg
Old Mar 29, 2018 | 05:32 PM
OverRover's Avatar
Have at it!
Old Mar 29, 2018 | 10:40 PM
Sweet! Thats the clarification I was looking for. Much appreciated.
So I replace the passenger side, inner and outer. Pretty easy job! It was indeed worn but I still have a clunk on that side. Darn it! I will replace driver side asap. Then onto the upper control arms I think.
Old Mar 30, 2018 | 04:12 AM
Be sure to check your sway bar links and bushings as well.
Old Mar 30, 2018 | 05:39 AM
Sway bar links I did first. But I did swap one back to the original after the new one failed in just a couple weeks (AC Delco). I may swap the passenger side back too, the old ones were in good shape. Sway bar bushings I did last week, OEM parts.
Old May 18, 2019 | 12:04 PM
Just an update related to my last post on this thread. Just adding that not much longer, weeks/a couple months, the other AC Delco front sway bar link failed. These parts did not last long at all. I got them from Rock Auto so I hope they were legit and not counterfeit. So I had been driving quite some time on the factory ones. A month or so ago a factory one, about 125,000 miles, finally started making some noise. I have since replaced both with Delphi band links. Will see how long they last. The one good factory link has no play but certainly is worn. I will keep it in the truck as a backup for now.
Kevin Rhodes
Jul 19, 2016 03:02 PM
DiscoCam
Jun 24, 2016 12:03 PM
Bone
Apr 2, 2016 04:14 PM
texasdisco1
Apr 9, 2013 06:16 AM
ebg18t
Apr 25, 2012 08:18 PM
