Sunroof drain tubes FIXED
Will try to do so. Been a few years since I have used image hosting to embed photos on forums, what's the easiest way these days?
to post a pic to the site copy the direct link to the image on the host site, then come here click the little box that looks like a pic with a mountain, a small window opens, paste link there hit ok
I finally had time to look into why my driver side floor was wet whenever there was a nice rain or snow melting. When I grab the elbow, it was torn in a couple of places. How are people fixing this? Is there a hose on the other side of the elbow that fell off? My first thought was to order a new elbow from the dealer but after sleeping on it, I think I am going to remove the elbow and slid another piece of hose on it and stick it threw the hole where the elbow was. Unless someone has a better idea.
Do you have sunroofs that open at all or just one with a broke motor?
I'd honestly rather trade my working sunroof for a plain roof with no openings
The drains in the C pillar are indeed for the sunroof, in addition to the two that run down the A pillar. If you examine the opened sunroof from the top, you will see a hole at each corner that corresponds to the respective drain. Pour some water into a hole and it will drain out under the vehicle.
The service manuals do show that there are two drains for the back of the tray that run down the c pillars, I'm assuming to drain water if you're on an incline facing skyward, or accelerating. However I didn't get to mine just yet as I don't think they are clogged. Will try to test and access them if it doesn't require too much disassembly, hopefully they will blow out fine
