Sunroof Leak at the car wash?
Old May 14, 2021 | 10:46 PM
Perfectphoto's Avatar
Default Sunroof Leak at the car wash?
On my 2007 LR3, my son and I took it through the car wash and it leaked a little on the front sunroof. Is that just a new seal or something more? I pulled the front air intake event and the drain tube is working as it should.
Old May 15, 2021 | 09:20 AM
DakotaTravler's Avatar
There are four drain tubes, not one.
Old May 15, 2021 | 09:24 AM
Great I will check that out.
Old May 15, 2021 | 09:30 AM
Two in the front. The driver side outlet is hidden, to the only way to check easily is to pull it out. Once the black plastic plate is removed, you will find it. But if they are original pulling it could cause it to break up. So its a gamble. I have found the rear two drains, while they can clog, are not usually rotted. Still a slight fuss to reach em.
s10lowrider1994
Sep 27, 2023 09:40 AM
sputnik62
May 28, 2018 10:50 AM
killerpav
Nov 18, 2013 07:37 PM
Livingintheskies
Apr 17, 2011 12:15 PM
