Sunroof Drain tubes
Old Nov 18, 2013 | 04:59 PM
killerpav's Avatar
Default Sunroof Drain tubes
Ok, so my tubes are leaking again. Quick thoughts, can i just plug the tubes and stop worrying about this problem?
Old Nov 18, 2013 | 05:17 PM
jafir's Avatar
No. Then the water would just rain down from the top most likely. You have to seal the sunroof shut too.
Old Nov 18, 2013 | 06:48 PM
willrok13's Avatar
Or just seal the sunroof. No need to plug drain tubes if sunroof is sealed. There's nothing to flow in them anyway (hopefully).
I used silicone caulk to seal the sunroof on an old DII (replacement trays can be difficult o find). Make sure you disconnect the switch and/or fuse so that the sunroof is not inadvertently opened and breaks the seal.
Old Nov 18, 2013 | 07:37 PM
jafir's Avatar
Right. Lol. That's what I should have said. Of course that only fixes the issue if the sunroof is the issue. Could be the a-pillars or the hvac leaking.
DiscoNoisebox
Jul 15, 2022 10:15 PM
aftermath431
Oct 4, 2013 10:43 AM
aftermath431
Sep 30, 2013 09:28 PM
bullhead
Jan 19, 2013 02:49 PM
mlelah
Freelander
Dec 23, 2012 12:17 PM
