All left blinkers not working.
Old Aug 16, 2023 | 10:43 AM
m_lars's Avatar
Default All left blinkers not working-SOLVED
I started to get rapid flashing on my left turn signal this morning. When I got to work I put on the left blinker, it flashed rapidly, then started to blink normal before I could even get out of the car to check which bulb was out. All three were working. Thinking this was very strange, I shut them off and turned them back on. This time it was rapid flashing and all three (front, back and door) were out. I also tried the hazard switch and the rights worked, left did not. I suspect of the multifunction switch, but don’t want to mess with replacing it if I’m wrong!
Has anyone else had this issue?
Last edited by m_lars; Aug 21, 2023 at 01:21 PM. Reason: edit title to show problem was solved
Old Aug 21, 2023 | 01:19 PM
m_lars's Avatar
After scanning with my GapTool, I had an error for a short in the left turn signal circuit that turned out to be just the rear bulb. The weird thing was that as I was tracking this down all the bulbs would randomly (infrequently) work. So it wasn't that the bulb burned out, it developed a short. It was not a Lucas bulb which may have been the cause of the weird symptom, it wouldn't be the first time!
Derek Gjessing
Jul 7, 2018 02:03 PM
djdart
Nov 14, 2015 01:03 PM
jimmyc
Dec 9, 2013 01:22 PM
bballjames
Nov 27, 2012 11:46 PM
LordOphidian
May 30, 2006 03:00 PM
