Suspension fault, not building enough pressure
Old Jun 19, 2018 | 07:05 PM
m_lars's Avatar
Originally Posted by thebruce
congrats on finding the issue! btw - how did you check the pressure?
Originally Posted by backroadnomad
curious about this as well.
Im also curious as to what the “gallery pressure” is. I can’t find a good explanation anywhere.
I checked the pressure with my GAP Diagnostic tool.
Best I can tell the gallery pressure is the pressure in the tank and plumbing to the valve blocks. However, the pressure is read in the area between the compressor and the first valve block, so unless the compressor is running, you don’t know what the system has in it. When the compressor is running you can watch the pressure increase until it kicks off and vents the head pressure off the compressor. At that point the “gallery pressure” reads ~11psi on mine. As soon as the compressor kicks in and the valve opens the reading jumps up, usually well above 100psi.
Kevindk9
May 26, 2023 06:11 AM
NewRover08
Feb 27, 2017 11:55 AM
chrisc2683
Oct 19, 2015 11:39 PM
Airstream345
Sep 7, 2015 09:42 AM
alti
Oct 25, 2013 10:45 AM
