Thump after braking
Old Jun 7, 2018 | 11:25 AM
Athana's Avatar
Default Thump after braking
Hi..When rolling a little and I stop solidly,.. a little thump is heard just after I brake.
Whats up usually?
A few years ago we had a more severe example of this thumping and it was control arms which were changed and it was solved..(I'm not sure if it was upper or lower set.)
If it's control arms...can only bushings be changed this time ?
Can it be all the bushings?
Thanks
Old Jun 7, 2018 | 12:24 PM
houm_wa's Avatar
Sounds like the lower control arm bushings to me. You can get just the bushings fixed but it's generally more straight forward to just replace the LCAs.
Old Jun 7, 2018 | 03:01 PM
abran's Avatar
Start the vehicle, put in drive, let off brake, start to roll, tap the brake. If you hear the noise... lower control arms.
Old Jun 7, 2018 | 09:30 PM
Athana's Avatar
Thanks so much.
I went to Mechanic who did front Rotors & Brake 10 days ago ..and he Lubricated the Bushings..I think it may not be happening anymore.
But will do the test recommended tomorrow,
Many thanks.
Old Jun 7, 2018 | 09:44 PM
I'd love to know how this is accomplished. I have never seen lube points on these
Old Jun 8, 2018 | 07:20 AM
abran's Avatar
there is a TSB for it. I believe it’s found next to the TSB outlining the procedure for changing out the blinker signal fluid.
Old Jun 8, 2018 | 09:20 AM
Silly me should have looked
Old Jun 20, 2018 | 10:16 AM
Athana's Avatar
He Lubricated something down there but it's made no difference.There is a thump after braking hard.
How likely is it lower control arms..90%?
This happened in the past but more severely and it was lower control arms.
Also ..what are effects of upper control arms going..thanks.
Old Jun 20, 2018 | 10:18 AM
Athana's Avatar
Yeechs..
jft1428
Mar 22, 2018 10:25 AM
AdrenalinPlease
Nov 20, 2017 10:32 PM
Zelatore
Jun 11, 2016 12:50 AM
asv4k8
Mar 7, 2011 07:29 PM
